Jun 22, 2016Explorer
wildmanbaker wrote:Philip.Saran wrote:
I have a Safe-T-Steer stabilizer on the front end and a track bar added to the rear of my MH. Keep the front tire pressure at 95psi and the rear at 100psi.
I was told the Cheap quick fix "can" break the links, has anyone had that problem?
I don't know of anyone coming forward with having problems with the sway bar end links breaking or bending. Shocks, sway bars will help with side to side rock, alignment will help with straight ahead steering, but the "tail wagging the dog" will require a track bar on the rear, and possibly the front also.
Tail wagging is often caused by "sawing" at the steering wheel to keep the MH in its lane. Adequate caster greatly reduces the need to be constantly turning the steering wheel back and forth.
To put it another way, my 35' MH doesn't have either a tail wagging problem or a track bar.
38,767 PostsLatest Activity: Jan 13, 2022
