Wes_Tausend
Jun 25, 2016Explorer
wildmanbaker wrote:Wes Tausend wrote:
Some thoughts on suspension...
I like the descriptive phrase of "saw steering" that Mark (427435) brought up. Good way put it.
The F-53, with an I-beam axle, must be similar to smaller, older 4X4 trucks with a live front axle..........
...........Increasing sway bar tension can also cover up a problem with bump-steer if it exists. Bump-steer is a condition whereby the toe-in changes with suspension spring compression/decompression. This appears when the truck leans during a sway maneuver and the spring compression change affects geometry of the steering tie-rod, which in turn pulls the toe-in setting out of alignment. This can cause a darting reaction that makes the sway escalate much worse and demands a frantic correction, or series of corrections, from the driver as though he is walking a tightrope. Very tiring and worse, hard to intuitively recognize the precise root source from steering feel. The truck just plain steers bad, that is the unsophisticated overall feeling.
Wes
What? Apples to oranges.... Bump-steer with a I bean axle? You probably have a usable though, but I am having trouble sorting it out.
wildmanbaker,
Good catch. You are quite correct that classical "toe-in" bump-steer will not occur with a solid I-Beam axle. I started to speak in general terms, but should have left it out of this discussion.
Bump-steer doesn't normally occur on a 4X4 F-250 either for example, because there is a single tie-rod from spindle-to-spindle and we could assume this is also true of the F-53 (Of note, F-250-350 4X4's use a pan-hard bar). Some very minor steering variation may take place during bump (spring compression) in that the drag link swings in an arc rather than perfectly moving vertically.
True bump-steer could more easily occur on an independently sprung smaller twin-I-beam 2wd truck though, since the tie rod is split. I'm not sure if some F-350 mini-homes use the twin-I-beam. Bump-steer should not be a major problem for either drive configuration unless some smaller truck is jacked up for off-road, with an extreme drag link angle.
Wes
38,769 PostsLatest Activity: Mar 30, 2026
