rjstractor
Oct 12, 2018Nomad
How hot is hot? 110 degrees might be uncomfortable to touch with your hand but harmless in terms of tank temperature. Propane tanks left outside in the Southwest will see temps considerably higher than that. Now if it's 200+ that's a problem. You don't want the tank to vent. Venting is harmless UNLESS the vented propane finds an ignition source, then you have a big problem!
38,766 PostsLatest Activity: Jan 10, 2026
