- Chum_leeExplorer
mjohnwwjd wrote:
2011 Jayco 29DS when traveling the propane gets so hot you can't touch it and it ticks. Is this normal and safe? Has always been like this from purchase. Mike
Your propane tank compartment should be open to the air (for circulation/ventilation) on the bottom. Is it?
The tank can pick up reflected infra red heat from the roadway below, but, it should NOT be too hot to touch. It is NOT normal and may be unsafe.
Chum lee - bobndotExplorer III
Did you buy it new?
That was my question too. I was thinking it was a used unit and a previous owner ran a new exhaust system too close to the tank. - reppoc12Explorer
Did you buy it new? If not how long has been like this since purchase. Maybe a longshot but you may want to check for recalls? - old_guyExplorerI think a trip to the muffler shop is in order but I think I would pay to have them reroute the exhaust pipe away from the tank
- JaxDadExplorer III
Old-Biscuit wrote:
I would take it to a muffler shop and have that exhaust heat shielded IMMEDIATELY.
Tank relief valve WILL spew propane if tank temps get over 130*F
Exhaust should NOT be heating the tank ....bad bad bad
I’m going to go the other way on this one, I doubt a typical muffler shop would have much experience with class A motorhomes, ESPECIALLY what is ‘normal’ or not.
Take it to a Jayco dealer, they will (should?) be able to quickly see if there’s something that’s not right compared to a ‘normal’ unit.
A manufacturer as big Jayco / Thor isn’t going to produce a unit with a propane tank next to the exhaust system, and if they had, I’m pretty sure we’d of heard of it in less than 7 years ...... - timmacExplorer
I take it this motorhome is on the Ford chassis and Ford does have the Y pipe on the passenger side where both exhaust comes together and that area does heat up where your propane tank is located, I would have a muffler shop put a large heat shield in this area. - bobndotExplorer IIII guess you are lucky to have found that.
How the heck did you notice that ?
I have never thought about taking the temperature of my propane tank . I think my DW would think I have really gone off the deep end regarding this rv. But I will check it now . :) - phillygExplorer III've never heard of or experienced a hot propane tank. How about checking it with a temp gun to see how hot it actually is. I don't want to be an alarmist, but that sounds SERIOUS?
- mjohnwwjdExplorerThanks Old-Biscuit!
- Old-BiscuitExplorer IIII would take it to a muffler shop and have that exhaust heat shielded IMMEDIATELY.
38,763 PostsLatest Activity: Dec 05, 2025
