mchero
Mar 31, 2017Explorer
Super Singles
Anybody running super singles on their class A??? For those of you unfamiliar with super singles they are a single WIDE tire/rim that replaces the duals on the rear axle(s) seen on some of the truc...
Two Jayhawks wrote:Ivylog wrote:
Mchero, you are the one confused. :S
Cement and trash trucks often use super singles on the front that are wider than the one used on a semi. Heck, many of the big DPs are using 365/80/22.5 on the steer and tag axles... I would call that a super single as they will carry more than the 17,000 lbs/axle allowed on a semi with tandem axles.
Many trucks as well as Prevosts, Newell's, and many production class A's run a 20K steer. However a 365/80/22.5 isn't considered a super single. A 445/50/22.5 is a super single.
Super Single
