mchero
Mar 31, 2017Explorer
Super Singles
Anybody running super singles on their class A??? For those of you unfamiliar with super singles they are a single WIDE tire/rim that replaces the duals on the rear axle(s) seen on some of the truc...
TDInewguy wrote:Groover wrote:
When you calculated the weight savings was that based on the original wheels being aluminum or steel?
One steel and one aluminum per side... that is what I calculated.
Steel - 79lbs
Aluminum - 49lbs
Super single aluminum- 56lbs
