Morgan_Creeker's avatar
Jan 15, 2014
Supplemental Braking System
I have recently had issues with the BlueOx Patriot Braking System. It has applied the brakes in an emergency fashion, as though the breakaway function was activated. The breakaway device was not even installed. BlueOx was no help, denying any culpability or reasoning for the action.
I was wondering who else may have had this experience.
  • Do you have to operate the blue ox system 5 times to bleed the vacuum out of the power brake booster? This step is required with the brake buddy system to keep from locking the brakes the first few times the brake buddy activates.
    Good Luck Don
    Good Luck Don
    I have the Blue Ox Patriot and I have no idea what you are talking about so I hope the answer is NO.
  • Dennis4809 wrote:
    I wouldn't tow without a breakaway system. Saw a Toad in the trees off the northbound side of I-75 in Oct. MH was on the shoulder southbound. With the amount of traffic on 75, they were lucky that the vehicle crossed the N bound lanes and missed everything but the trees.
    If a person USES enough safety chains AND cables...the toad may "break loose" but its never going on a trip of its own down the highway
  • Yep if got the safety chains it shouldn't leave you, but what going to happen when you stop? Your toad is going to run in to YOU.And tear up your toad and the back of the MH. But if the break away applies your toads brake and you have the safety cables you'll drag your toad until you stop so it doesn't run into someone else or into you.Might save a lot of your money.
