wa8yxm
Jul 23, 2014Explorer III
I would have to say some kind of motor home controlled is best solution as well, however there may be another solution.
Contact the surge brake manufacturer.. I will explain briefly how surge brakes work.
When you brake the trailer presses against a SPRING in the hitch and this movement operates the brakes, either by straight Mechanical (system of levers and cables) or by hydraulic means or a combination of the two.
Clearly, the spring (if it exists) needs ajustment, or if it does not exist, installation.
38,769 PostsLatest Activity: Apr 04, 2026
