TechWriter
Apr 19, 2015Explorer
tommy g wrote:pianotuna wrote:I respectfully disagree. The Progressive protects from surges as well as both high and low voltage. It also checks for ground connection, polarity and proper cycle before connect-thru as well.
Hi,
Ask yourself which causes more damage. Surge or low voltage.
Low voltage causes progressive permanent damage. An autoformer with surge suppression built in may be a better choice.
I always check voltage under load and polarity before I plug in.
Both the Progressive & TRC Surge Guard protect from low/high voltage by cutting power -- effective, but there is a better option.
An autoformer (or voltage regulator) "boosts" low voltage (to a point) so you don't lose power.
I think an Autoformer/Surge Protector combo is your best best.
38,776 PostsLatest Activity: May 15, 2026
