pianotuna
Apr 23, 2015Nomad III
Hi,
Tolerance is often (but not always) 10% so 115 name plate suggests that 103.5 is the lower limit. With 120 volt that becomes 108 volts.
I'll stick with 108 myself for the lower limit.
I do know that last year at a campground on a hot sunny day I had to turn off everything except for the air conditioner. This summer if it is hot, I'll spend the money for a 50 amp site (if available).
The air conditioner was drawing over 1900 watts. That is a sure indication that voltage was too low for my comfort zone.
The thirty amp pedestal breaker blew twice with just the air conditioner running. I suspect old tired breakers and minimal wire size in the RV park.
There is an autoformer in my future.
CA Traveler wrote:
OK But what is the lowest voltage for the motor? My Dometic says 115V period. So do I turn it off at 114V or at 107V or whatever?
And your motor may be different and it may not be 108-132?
Just raising what-ifs?
38,776 PostsLatest Activity: May 15, 2026
