pianotuna
Apr 23, 2015Nomad III
According to Dometic, amp rating on a 13500 btu unit is 13.4 amps. Locked rotor amps are 63. They don't list the name plate voltage. The do want #12 wire for runs under 24 feet. More than that and they suggest checking the national electric code.
Dometic air conditioner
If we assume 115 volts then wattage is 1541. I know I've seen as low slightly under 1200 and as high as 1900. At 1900 and 106 volts that's over 17 amps flowing through the motor. I can't imagine this is good for it, as a 10% tolerance would be about 14.75 amps.
38,776 PostsLatest Activity: May 15, 2026
