10forty2
Jul 29, 2015Explorer
After losing my HVAC t-stat last weekend, and having to spend a warm night without A/C, I am going to order a power management system that plugs into my shore line and then into the pedestal....not the cheap kind either. I want something that will protect my equipment from low voltage and high voltage surges as well as improperly wired supply outlets. Losing an A/C unit is expensive, as well as anything that's plugged directly into the 120VAC outlets that are not powered through the batteries.
With that said, though, on most boats I have knowledge of, the majority of electronics on there are 12VDC. The shore power only supplies power to the battery chargers and a few outlets with are likely also powered by a DC-AC inverter. So with that configuration, you already have a filtered power system. Low or high voltage may take out your inverter but most likely wouldn't take out your 12VDC systems since they are running off the battery bank.
