chuckbear
Jul 29, 2015Explorer
10forty2 wrote:
After losing my HVAC t-stat last weekend, and having to spend a warm night without A/C, I am going to order a power management system that plugs into my shore line and then into the pedestal....not the cheap kind either. I want something that will protect my equipment from low voltage and high voltage surges as well as improperly wired supply outlets. Losing an A/C unit is expensive, as well as anything that's plugged directly into the 120VAC outlets that are not powered through the batteries.
With that said, though, on most boats I have knowledge of, the majority of electronics on there are 12VDC. The shore power only supplies power to the battery chargers and a few outlets with are likely also powered by a DC-AC inverter. So with that configuration, you already have a filtered power system. Low or high voltage may take out your inverter but most likely wouldn't take out your 12VDC systems since they are running off the battery bank.
Thanks but our boat and most everyone else's we know all have heat/AC systems, sometimes multiple ranging from 13 to 20K BTU, microwaves, electric stove tops, coffee pots, toaster, ice maker, TV, DVD player, Satellite receiver, multiple small appliances like hair dryers, fans and of course our battery chargers that can run up to 150 amps. I'm sure I am forgetting a few other things. All of this must be integrated into the 12 volt system and properly grounded to avoid electrolysis. In addition, the inverter and generator must be properly wired into the systems. Much more complex than most RV's but also similar. You need to deal with all of this in a salt water environment. Dockside power outlets corrode quickly, Dockside power wires can be seen hanging in the water and dockhands that know nothing about electrical systems wire the dock. But I'm still learning the nuances of the RV. Chuck
