iquilt888 wrote:
Bit the bullet and bought a Progressive surge protector.
Now my question is can the surge protector, it's the portable one, be used between the generator and the coach hook-up? Not exactly sure how that would work but is it even possible?
Portable no or at least not easily unless you plug your shore power into the generator. If you return it for a built in unit it can be installed after the power transfer switch and before the breaker panel which will give you protection from problems with either power source.
I have a 50 amp portable. Was the second expense related to the coach with the first being the down payment. Have yet to remove it from the end of my shore power cable after three years. had it trip a couple of times due to low volts which is pretty hard on the AC compressor.
