WILDEBILL308
Mar 31, 2018Explorer II
S1njin wrote:
So what is the consensus best order of suspension improvements on a E450 motorhome?
My guess:
Proper tire pressure
Front end alignment
Rear Sway
Front Sway
Shocks
Steering Stabilizer
Rear Track Bar
Am i close?
I would add to the Front end alignment, make that an all wheel alignment. The next thing I would do is a track/panhard bar. This helps cut down on the movement of rear of the coach. You have a lot of overhang behind the rear wheels and it will move the whole coach in wind or big trucks passing.
Look for the cheap handling fix on google.
Look at changing out the rubber bushings in the sway bars with polypropylene, it will stiffen up the ride.
Shocks, it depends on age/condition. Yes stiffer shocks will help.
I am not a big fan of the stabilizers but if nothing else makes you happy with it go ahead and try one.:D
Bill
