Desert_Captain
Mar 31, 2018Explorer III
You need to keep in mind that a Class C is a 1 ton cutaway van. It is never going to handle like your family car. :S
IMHO: Any Class C that does not drive and handle well with the proper tire pressure and a decent alignment is the WRONG coach. There should be no need to add aftermarket garbage to get your coach to drive decently.
If it did not dirve well on the thorough test drive {you did do a thorough test drive, right?} adding thousands of dollars of aftermarket equipment is a waste of your time and money. Will quality after market gear improve the ride and handling? Perhaps, but it is only money needlessly/foolishly spent due to buying the wrong coach in the first place.
Quality coaches {like Coachhouse, Born Free, Phoenix Cruiser and yes, my Nexus et al} need nothing more than proper psi and alignment to give smooth, stable ride and handling. Some manufacturers actually recommend getting your brand new $100K+ coach aligned and the suspensiopn modified right off the showroom floor. Would you buy a $100k SUV that came with the same recommendation? :h
As always... opinions and YMMV.
:C
:C
