Hank85713
Apr 01, 2018Explorer
I had some initial issues with the 2012 winnebago aspect. Looked at alignments, new stabilizer all the stuff you have listed for the most part. Found that having the tires at a decent pressure, not the max helped greatly as did increasing the air in the rear airbags to a minimum of 55-60 PSI. You do have airbags dont you? Anyhow that took all the fighting out of the system, still may have some push/pull from passing big rigs but that is typical of all slab sided vehicles. Bow wave get everyone all the time just depends on your set up as to how much effect it has. rv weighs in at around 13K 1/2 of all liquids, black grey tanks empty. We dont carry much as there is little room for extra stuff anyplace on the rig. Small outside storage bins and not much inside either.
if you have airbags play with them to find sweet spot, same with tire pressures. I run 60 in front 65 in rears like I said we dont carry much load do tow a Hyundai but it really does not add to the coach weight just draw weight.
