OFDPOS
Apr 03, 2018Explorer
S1njin wrote:IAMICHABOD wrote:
Front Sway : If you don't have levelers then upgrade the puny undersized stock Anti Sway Bar with a Hellwig.
What do levelers have to do with upgrading the front sway bar?
Think you got him mixed up with me.
What does levelers have to do with upgrading the puny front "Anti" sway bar you ask...
Before you have the "Anti" sway bars replaced , stand up in the middle of the MH now rock back and forth ..
Then do the same thing again once the "Anti" sway bars have been swapped out..
You won't "sway" back and forth as much..
Your better half won't scold you as shes putting on make-up etc while your moving around in the MH..
I'm not a very big person 5'11 218lbs and before I replaced the "Anti" sway bars just stepping on the step going into the MH it would lean/sway a little bit.
So that's one big reason why I said "If you don't have levelers then upgrade the puny undersized stock "Anti" Sway Bar with a Hellwig"
I ordered both F&R Hellwigs from the same place you did, I received them with 5 business days..
Its spring time and they tell you it will take 2-3 weeks and all 3 times I ordered them they showed up within 5 business days.
Oh and when the Brown truck shows up with them , the boxes will be ripped open. At least all 3 times I ordered them the boxes were ripped open.. All parts were in sealed plastic bags or little boxes taped inside.
If your home when the deliver , might want to do a quick look to make sure all the nuts, bolts , links etc are there before signing for them.
