OFDPOS
Apr 04, 2018Explorer
whizbang wrote:
OP.
Delete the sway bars and track bar and your original list is right on.
I am not a fan of sway bars. A little articulation is a good thing. Ask any 4 wheeler. Seriously, if you over stiffen your suspension, you will experience porpoising at highway speeds.
Uhm I like most would kindly disagree with your comment.
We are not out 4 wheeling , rock crawling with our MH's.
We are trying to keep our MH's between the lines , fighting cross winds, trucks passing and pushing us .
Going around corners and not swaying or pulling out of parking lots at angles so we don't drag the tail end yet NOT swaying back and forth doing that etc.
Anti Sway Bars and Trac Bars are not going to cause you to porpoise at highway speed. Bad/worn/wrong type shocks on the other hand will definitely lead to porpoising tho through dips ..
