carringb
Nov 21, 2014Explorer
I believe its doable. I've seen pics of it done once.
Both years use CAN-BUS networks, so the wiring should be the same. You will have to have the new instrument cluster programmed to work with your PCM, as they go through a VIN check at startup. That step will require a shop with a Ford IDS terminal. Or, if you buy a new cluster of from a certified rebuilder, they can preprogram the VIN (and mileage).
38,774 PostsLatest Activity: Apr 26, 2026
