dougrainer
Aug 15, 2020Nomad
RustyMacIntosh wrote:
OK let me call Dometic and see what I can hussle up, I have a feeling Fuzzy has had experience....
While Fuzzy has had experiance he is not correct about DIP switches. The DIP switches are for a specific Dometic wall tstat system which you do not have. Are you positive you have Dometic? Fleetwood usually used RVP(Coleman). BUT, you need to go with the same manufacturer of your roof top units. BOTH RVP and Dometic, the upper units are what they sell. They all fit the existing controls for the original system. So, if either Dometic or RVP, the upper units will have a standard plug for the RVP or Dometic and will plug into the existing control system for the AC system. To save money you want a Brisk Air if Dometic or a Mach 3 if RVP. DO NOT GET A PENGUIN. Doug
