bferrara
Sep 14, 2015Explorer
sway bar and steer safe
I have a ford f-53 chasis with steer safe. is it possible or necessary to add a sway bar or does the sway bar attach to the steering assembly the steer safe is already attached to.
10forty2 wrote:
Hmmm, I just assumed that all the F53 chassis headed for motorhome factories came standard with front and rear anti-sway bars already installed. Seems like it would almost HAVE to be standard on heavy truck chassis regardless of where they headed after they left the chassis factory. In essence, they are just big torsion springs that keep side-to-side body roll at bay.
With that said, if you DON'T have anti-sway bars (not track bars...there's a difference) already installed I would HIGHLY recommend installing front and rear anti-sway bars with poly bushings.
To answer your question on the Steer-Safe, I feel pretty sure that installing an anti-sway bar wouldn't interfere with it. I don't have one on my coach, but best I can tell from the videos showing their installation, the Steer-Safe and Safe-T Steer and others like it connect onto/between the steering linkage and to the frame to dampen sudden jerks to the steering linkage from road hazards or blowouts....just like shock-absorbers do to reduce up and down bounce from the road.
