jimx200
Aug 03, 2016Explorer
j-d wrote:
We have an E450 and replaced both OEM sway bars with Hellwig bars. Same size and steel as Roadmaster but far less expensive. The new bars helped immensely, both on the road and on the campsite.
I visited with John at Hendersons Line Up in Grants Pass Oregon. One of the top shops in RV ride and handling. He agreed with the same 5-degrees of caster like Harvard mentioned above. Also said that adding a Safe-T-Plus steering stabilizer worked like setting caster to 5-degrees. It'd be the silver 31-140 model. The OEM damper brackets won't fit, you need a S-T-P bracket kit as well.
A Damper, like OEM and replacements from Monroe and Bilstein, absorb jolts. They don't help keep the steering centered. There's a kit called Steer Safe that centers the steering. Safe-T-Plus has hydraulic shock absorbing AND coil springs to center the steering. So does Roadmaster's "Reflex" unit but it uses one exposed spring instead of S-T-P's two enclosed springs. Henderson sells a lot of Roadmaster products, so if they select S-T-P instead, that's what I'd do.
Thanks much guys!
JD, you mention you replaced BOTH OEM bars on your E450. I see one solid (apparently) OEM bar on our E350 in front and just shocks in the rear. Does the E450 have both front and rear bars or did I miss seeing the rear bar5 on our E350?
Would a truck tire shop be my best bet to set camber? Regarding what the gentleman, John at Hendersons in Oregon said: so if we go with the Safe-T-Plus, we would not need to set camber? Thanks for this excellent and detailed info., appreciated.
38,776 PostsLatest Activity: May 15, 2026
