SoCalDesertRid1
Aug 04, 2016Explorer II
Toe in set to the maximum works good on most Fords to keep it steering straight. I've had the toe set to max on all my Ford trucks and it really does help the steering.
Heavy duty front and rear sway bars with polyurethane bushings will help alot to reduce body roll/sway.
Most Fords have soft rear springs. Those soft rear springs also contribute to body roll/sway. Stiffer rear springs help alot. All my Ford trucks have had stiffer rear spring packs in the rear.
38,776 PostsLatest Activity: May 15, 2026
