Skeeterhawk's avatar
Skeeterhawk
Sway bar bracket
The sway bar bracket that attaches to the frame. Should it be centered vertically or
Mount near the top edge of the trailer frame? I know it mounts 24” from center of hitch.
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post in the RV Forum which corresponds to the subject of your topic. Thank-you!"
  • If its a bracket that clamps on the tube of the A frame, like a Equal-iz-er hitch, bear in mind that the bars will be pushing down on the bracket with considerable force. If it has vertical movement before tightening it Bracket taller than the tube it fits on, I would be inclined to put it all the way down, because it will probably slip that way as time goes by if you try to mount it up higher.
    If this is the bracket for one of the flat anti sway bars that connects to the hitch separate from the weight equalizing bars, I would think you want it nice and level with the trailer frame, but I have no experience with them.
    Charles
  • What brand?
    Usually the bracket itself dictates how it's positioned vertically on the A frame.
