Daveinet
Aug 27, 2013Explorer
wilanddij wrote:X2 Steering stabilizer is normally considered a bandaid and should only be used as a last resort. You should note that a sway bar is NOT a trac bar. Your coach likely already has sway bars. sometimes they can be relocated, or stiffer ones installed, but those effect the ride quality. The trac bar or Panhard bar should not have any impact on the ride quality, but will likely make a huge difference in handling response.
You would probably be better served by adding a Track (Panhard) bar to both front and rear axles. These keep the axles and chassis tied together laterally, and reduce side-to-side play which causes your coach to be a "handful". Do a search on Google for "rv track bar".
