rgatijnet1
Aug 28, 2013Explorer III
I have the W22 chassis and do not have any issues with steering, pushing from passing trucks, or high wind wandering. I routinely travle in the Great Plains when high winds are the norm. The chassis already comes from the factory with a heavy duty sway bar. I did add a hydraulic steering stabilizer. I have not added, and do not feel that I will ever need trac bars. Before you spend the money on any suspension "fixes" I would check your coach loading and front end for looseness. Make sure that the front axle is loaded close to max and then go with the original mechanics suggestion about a steering stabilizer. I think you will find that is all you need.
