IAMICHABOD
Oct 31, 2019Explorer III
Welcome to the forum,being you are new and own a former rental, you may not have seen the Rental Thread there is a lot of good information there.
I went thru it and found that Hellwig seemed to be the one most talked about.Here is one of the quotes from a Majestic owner.
If you have any questions just ask I and many others may be able to help. Join in and tell us about that Former Rental.
TRM1 wrote:
This thread helped tremendously,
My primary focus so far has been suspension. We've installed Bilstein HD shocks and steering stabilizer and have Hellwig front and rear sways coming. My wife and girls don't like the rocking motion so I'm doing my best to eliminate it. Bushings on the sways are perished, so looking forward to an immediate improvement. Just the Bilsteins made a huge difference, and if you haven't replaced your steering damper, you should. When we took the stock one off it clearly had no damping left in either direction. I drove the same bumpy road before and after and 80% of the deflection and bump steer are gone. The rest I attribute to a front sway bar that isn't even connected with the I beam at this point.
