dougrainer
Oct 23, 2019Nomad
You probably have the Coach Battery disconnect OFF. When plugged into 120 AC power, with the disconnect OFF, the Converter or Inverter/charger will supply 12 volt power. ALWAYS leave the battery disconnect ON when using the RV. Now, if you are not talking about having to turn the battery disconnect ON, Then you do have a problem. Doug
PS, there is no switching needed when you unplug AC power---2 different systems.
38,763 PostsLatest Activity: Dec 05, 2025
