jeromep
Nov 18, 2020Explorer II
fred42 wrote:
Rusty,
I do not have handling issues of any kind but the front leans an inch or two lower on the drivers side. No visible damage to the springs. I was considering a front only airbag install.
I see the kit:
1990-2007 Ford F53 Firestone "Ride-Rite" Air Bag, front Model: 2070
requires a 3/8 hole be drilled in the frame. The Air Lift LoadLifter 5000 88140/57140 appears not to need drilling as you said.
Other than that issue, did you or others intentionally avoid the Firestone product?
thanks,
Found this entire thread interesting. I purchased a 95 Bounder 34j which had the Ride-Rite air bags front and rear. Previous owner said to run them at 70 lbs. So far I've not had any issue with that recommendation. It's a pretty firm ride, but crosswinds are a bit easier to handle than I had expected with a firmer ride. Previous owner had purchased a '14 Bounder and had not yet done anything with the suspension and was already complaining to me about how much wallow the new motorhome had compared to the old one.
