MrWizard
Jan 17, 2021Moderator
The rusty looking area is a section of the body flange, covers a huge area of the chassis rail, the mounting holes I'm trying to drill must go thru flange and then the chassis, I got one 1/4" pilot hole almost thru, lateral force into the steel while squatting in the wheel well , is not equal to the force you can apply when you can bear down, or lay on your back and push up/in with all your strength because your back is against a solid object like the ground, if you can not be braced to apply full strength, the only force that can be applied in a horizontal lateral 90° angle is equal to your weight, especially when squatting, not the same as standing with legs spread one foot behind you, in the CLASSIC pull push sideways stance leaning forward into what you are doing,
I had the feeling this could be difficult physically, (technically it's easy), I just did not think it would be that difficult to drill those freaking holes, and it was hot yesterday 88° , same again today, got to check and tighten the lug nuts, before going to the gas station
