Stim
Jan 18, 2021Explorer
I have drilled a few hundred holes in semi frames mounting axles/equipment and I can't imagine using battery tools!
We used a 1/2" drill with a "D" handle AND put a chain around the frame through the "D" in a loupe. With chain tight you rotate the drill which forces the drill into the hole.
In your case you might try a rope around the frame and drill to get more force.
You also must use slow speed with lub.
