MrWizard
Feb 07, 2021Moderator
Southern California, wish I was visiting in 'Q', I think 2016 was my last trip there
First air spring bag is installed
New cobalt steel drill bits, made the difference
Finishing the first hole was easy, lower hole on left side of bracket
Drilling 2nd hole, wasn't too bad, thru the frame , no flange, fender washers to make a gap filling spacer,no body flange ( yes I worked counter clockwise from the first hole position )
Number 3 ,forward facing upper hole above number 2, for right side of upper bracket, thru body flange then frame, same as hole #1, that was a lot more work, than drilling just thru the frame , but the cobalt drills did the job, ##4 same thing,
Final bolt down and running the airline was easy
Hopefully
Doing drivers side today/Sunday,
Tried last weekend, could not get wheel lug nuts loosened
Bought an electric impact wrench, weighs 12.5# ,has 450 ft pounds of torque, with good luck I might not break an arm today, this side will require more prep work, there are.. brake lines and fuels along inside of frame member, don't want to damage those items
Hopefully
