mpierce
Sep 25, 2016Explorer
Mile High wrote:
Something definitely wrong there - they don't show any axle weight for the tag. Either somebody swapped your vin tag, or the manufacturer messed up (probably the latter).
The front axle seems light at 6,000, but OK. The rear dually, OK at 10,000, but there is no way both the main drive axle and tag would be 10,000 together.
Even if the tag was only rated for 6,000, that would put you at 22,000 GVWR.
I bet the Chassis was made with only the drive axle, thus the tag without a tag axle listed. The Mfg. then added the tag axle during mfg of the MH.
38,768 PostsLatest Activity: Nov 21, 2015
