Mr.Mark wrote:
Kayteg1, so, obviously your tag doesn't automatically lower. Do you get an alarm? I forgot what kind of coach that you have.
Our Dynasty automatically lowered, the new coach gives me an alarm.
MM.
Same here, I can force the tag to stay down but in the auto setting it raises in reverse and (I think) at speeds below 10-15 mph. The problem with keeping it in auto is that it uses a LOT of air and does allow the rear to settle a bit until the pressure builds back. That coupled with a lot of brake use will set off the LP alarm. I almost never raise mine.
