mpierce wrote:
bluwtr49 wrote:
Thanks again for the replies and they have been very helpful in clarifying my thoughts.
I really like the thoughts of moving my steer tires to the tag position but I'm not going to use the tag tire in the steer position....I feel the sidewalls are way to stiff. When I get to OR next month I will consult with the local Les Schwab dealer regarding what tires and pressures to run on the tag longer term.
As to why lower the tag axle loading: I do that to balance the fore and aft axle wts. By dropping the tag air pressure it transfers wt from the front axle back to the drive and tag axles. This has a lot of long term benefits especially if the front axle is close to or over the wt limits. This is the purpose for which tag axles are installed. In my case I'm currently running ~12,000 lbs on the front and would like to drop that to about 11,500 or so. Naturally one does not want to go overboard so there is some trial and error involved.
Partially correct. Dropping tag pressure will lower front wt. But, you say it adds wt. to the drive AND tag. Incorrect. Taking pressure out of the tag air bags will also LOWER the wt. the tag is carrying. ALL the added wt from the front and the tag goes on the drives.
Be aware too, that by lowering the wt the tag is carrying, you are much more likely to lock up just the tag tires in a quick stop, flat spotting them.
You are correct and I mis-spoke regarding transferring wt. to the tag. It is my intention to transfer wt from the steer axle which is loaded to ~ 85% to the drive axle which is loaded to ~70%. Plenty of capacity to play with. The adjustment is easy, just drop the tag air pressure using the regulator/pressure gage assy in the aft bay.
As for the tag potentially locking up in a hard stop....might or might not be an issue depending on how well the ABS works but I put that at a very minor potential problem and one that can be easily remedied if indeed a bit of flat spotting occurs.
