I am looking for info on a tag axle M/H. I plan to purchase a used M/H shortly, I can't decide if a tag axle is the worth the extra cost. I have decided on an Allegro bus.I presently own a 2005 38' co...
It's true... once you've had a tag axle coach you'll never go back to a non tag. Only problem is with 9,000+ lbs of CCC it's easy to keep too much STUFF that you would have to throw out otherwise. At 40' or more it's hard to have much CCC without a tag and the cost of two more tires every 10 years is worth it. I still put in back to back 12+ hour days as my Monaco RR10S handles that well, even with a strong cross wind or when passing a 18 wheeler.
