Dougjpr's avatar
Dougjpr
Tag axles
Do all coaches with tag axles have a option to lift the tag ?
If not, how would you know? If you are viewing coaches online.
I would figure that if I was seeing a coach in person I would be able to find a switch labeled as a tag lift or a dump.
Just curious as I continue to try and learn more about these coaches so I can make an educated decision when/if we decide to buy.
Looking at 2005-2006 model years, mostly Newmars
Thanks
Doug
  • Ivylog's avatar
    Ivylog
    Explorer III
    The big Monaco lift and will automatically go down when it shifts into 3rd if you forget to lower. I rarely raise mine unless I'll be doing several sharp turns. A raising tag would not be on my "Must have list".
  • Well Newmars now are using Freight liner chassis which have the lift tag and you can also steer the rear to make turns a lot easier. Most of these are on high end coaches. They also have the Z - TRW comfort drive that some really like.
    You might find some Newmars still using Spartan, but they had made the switch to Freight liner a few years back.
