Bill___Kate
Jun 01, 2014Explorer
DennisRFreitas wrote:
We just purchased the Dish Tailgater. For the most part I love it. But I have an issue that i was wondering if anyone has had this problem. The only way I can get a signal is to run the Coax directly from the Satellite to the receiver. (Thru a Window) If I use the built in satellite coax connection for the living room i can not locate a single satellite? I have checked the RV connection and all are tight. Has anyone heard of this type of problem? Thanks Dennis
The tailgater is a small, lightweight antenna - which has obvious advantages, but due to the small size, is limiter to the strength of signal it can acquire.
There is a significant signal loss in the co-ax at each connection, so depending on you set up, you are probably best setting up for direct connection whenever possible. Or update to a better antenna - like the Pathway X2
