Mile_High
Dec 27, 2017Explorer
Solo wrote:I suspect you are correct - Both my SF25QW and SF20QW suburban furnaces draw 7.0 amp each. That 14.0 amps when both running. The furnaces are tough on battery draw.
I have no data to support this comment but, I suspect operating a hydronic Aqua-hot heat system with the diesel burner and then using batteries only to operate the pump and the small fans at each heat exchanger on our coach would require significantly less battery power than running a propane fired furnace like we've had in our other motorhomes.
