valhalla360
May 18, 2020Navigator
Propane needs venting. The question is can you safely modify the trailer to accommodate it. We had one on our boat and it didn't give even heat. Went from cold to scalding and back...wound up wasting a lot of water trying to get a steady temp.
On a 30amp rig, it's not really practical as total wattage available will limit how hot the water can get.
With a 50amp rig, it is possible to pull 240v power but you have to wire it up correctly and using cheater plugs to connect to 30amp pedestals can be problematic.
38,770 PostsLatest Activity: Apr 12, 2026
