Dale_Traveling
May 19, 2020Explorer II
There are small electric point of use tankless than might work. Either way the owner is looking at a few hundred just for material. Add in another couple of hundred more for the electrical and plumbing work if you or he can not do the mods for something new.
Might need to consider either a repair of what's there or replace with the same. The coach probably has a 10 gallon which he could probably replace with a six which will free up a small bit of room plus would cost less than a 10 gal. Might be something used on eBay or Craigslist otherwise a new complete model is somewhat north of $300 with DSI (no pilot light) and secondary electric heating. Swapping for the same is not technically difficult and may be a two hour job.
38,770 PostsLatest Activity: Apr 12, 2026
