Mr.Mark wrote:
holstein13 wrote:
Mr.Mark wrote:
Shirley, I guess my question is.... are you sure that the tankless is working properly?
We have a hot water tank AND a tankless for the shower. I turn off the shower to lather up and the water is hot no matter how long I keep it off and then restart.
MM.
Unless I'm mistaken, I'd imagine your tankless is diesel powered, not propane. Am I right?
Ours is electric as we don't have propane on board. Our diesel Webasto system will heat water similar to an Aqua-Hot. We have a 20 gallon electric water heater.
MM.
By definition, the 20 gallon electric water heater is not "tankless." So if you are getting a "tankless" instant on heater, it's coming from your diesel burner. Otherwise, you are getting your hot water from your 20 gallon electric water heater.
