udidwht's avatar
udidwht
TBI Min idle speed spec
Looking at the 1994 service manual for 454 TBI under fuel systems (Section 4-4A) the 'Min idle speed' setting is... (Factory set screw)
For the 7,4L auto trans in Drive is 625 (+-25rpm) Closed loop
Controlled Idle Speed is as follows:
454 7.4L in Drive 675 (+- 25rpm) IAC count 5-30 (Closed loop) at operating temp 196-222F (add 2 counts for every 1000ft above sea level
The 'controlled idle speed' is obtained by the control module positioning the IAC valve. A high/low coolant temp or AC clutch engagement may signal the control module to change the IAC counts.
IAC counts will be above 60 if idle is too low and zero counts if idle is too high. Things to check if so...
1. Vacuum leak/s
2. System too rich
3. TB obstruction
4. PCV issue
5. AC issue
  • opnspaces wrote:
    Is there a question in this post or is it just information?
    Just info. I've seen and been asked of it often enough that I figured it would be good to post it up.
