Bill_Satellite
Jul 02, 2016Explorer II
I have had great luck with Visio TV's. As mentioned above you are not looking for an RV TV but rather a TV that will fit in your RV. Take a look at the space available and use that as a guide to the TV you want to install. The new TV's "rectangular" shape may require some modifications if you are replacing an older "square" CRT type TV. A new 20" LED/LCD TV will not fill the hold left by a 20" CRT TV so you may need to go bigger and that means you may need additional width and make some modifications to the way the TV is mounted.
38,769 PostsLatest Activity: Apr 04, 2026
