goufgators
Feb 13, 2019Explorer
goufgators wrote:dougrainer wrote:mrmichael80 wrote:
Check for a reset button on your inverter if you have one
Most Motorhomes, if you have the smaller Inverter, power the entertainment systems. If it fails or the breaker ON the Inverter is tripped you lose power to the entertainment 120 plugs. FIND the Inverter and check its power and reset buttons. Doug
Any idea where the inverter might be located? 2017 Winnebago Sunstar.
OP: Found the inverter control panel. Maybe now I can trace the problem. When (if) I locate the culprit, I'll post that info. Thanks to all who responded.
38,774 PostsLatest Activity: Apr 26, 2026
