RLS7201
Aug 25, 2018Explorer II
dougrainer wrote:RLS7201 wrote:dougrainer wrote:
That outside door you found is to allow fresh air in to the Evap and heater core. When you go to MAX AC, that door closes and it recirculates air from the cab interior. THERE IS NO BLEND DOOR. As I stated, Gas model Motorhomes do not have the fancier blend door systems Auto's have. I have and still am working on Motorhome Dash AC systems for the past 38 years. Doug
Except for Fleetwood, which used Denso HVAC with a blend air door, NOT a water control valve.
Richard
NOT talking about Fleetwood on this post. Tiffin also uses the Denso system which has Blend doors. Doug
But, but, but, you stated "As I stated, Gas model Motorhomes do not have the fancier blend door systems". Your statement included ALL MHs. So one would assume you was unaware of the Denso system. I can only read it as you wrote it.:(
Also, thanks for the tip on the Chrystal Clear DAP. Love it!
Richard
