Dutch_12078
Aug 26, 2018Explorer III
By balancing the temperature control setting and fan speed, we've found our F53 heat to be relatively easy to maintain within our comfort level. Turning the temp control/coolant flow rate down for instance, while turning the fan up a notch or two, lowers the output temperature more effectively than just turning the temp control down. A blend door would certainly be more effective, but re-engineering the system is not something I'm about to jump into given the relatively short time we're traveling versus parked and living in the coach.
