I am trying to test my 6 volt batterys and I have a hydrometer! My problem the directions tell you the readings for 12 volt batterys What do you do for 6 volt???
What are the SG readings? Hydrometers do not give voltage.
And, how much variance is there between cells. That will give you an indication as to whether your battery just needs a recharge or if one cell is bad.
