johnwalkerpa1
Sep 09, 2022Explorer
MDKMDK wrote:Tom/Barb wrote:
OEM tires what came from the factory on the coach? really dump ??
How old? Date code ? maker ? truck tire or coach tire?
Good questions. 2015 to 2022 is probably right around the "time to replace the aged out OEM tires". Maybe just a bit past due?
I'm at 5 years out from the chassis factory, with *only* 35,000 miles on the OEMs, and I started watching mine for odd or uneven treadwear and anything else, at every stop on the road.
Interesting that the TPMS didn't note any issues, and didn't prevent the catastrophic failure. Their scope of usefulness is limited to slow leaks only. When one decided to go, the TPMS just watched it happen. Regular checking and a good pressure gauge is still worth having.
Yes, they were a bit past due to be replaced. Original Michelin LTX from 2015 date code. Still about 3/4 tread. I thought I was ok for a while yet since it’s garage kept and no dry rot or cracks. But guess I pushed them a little too long.
Yes, pressures and temps were good. I suspect I lost a cord/belt.
38,782 PostsLatest Activity: Sep 10, 2026
